Posted: Wed Jul 26, 2006 4:14 pm Post subject: |
indeed he will be using the steering - hopefully I will find him some power steering componenets to make it even better  |
jace Wannabe
Posted: Thu Aug 10, 2006 3:43 pm Post subject: |
Had MOT last week and failed on a few things and not helped by the fact one of the hoses blew off whilst on the ramps.. oops :smt104
So just need to bung some new discs on the front, steering idler. steering control rod rod thingy... basically all the bloomin things I'll be removing when I fit the T25 stuff
Hopefully re-test tomorrow and back out on the road
Happy Dayz
Alex (FTS) Jedi Guardian
Posted: Fri Aug 11, 2006 10:40 am Post subject: |
Good luck on the MOT today fella.Fingers crossed! _________________ www.faltownskateboards.com |
easy-does-it Jedi Guardian
Posted: Tue Sep 05, 2006 7:52 pm Post subject: |
Nice van dude
Im a bit slow so you'll have to bare with me... did you originally fit the engine?
Im thinking of 16v mine now and was wondering how you go about the mounting process? ( fanar fanar)
Do you attach the engine to the box then work out how the angle goes or have you mad lot already patented dimensions on this
oh and does the t25 box mount on the exiting mounts or do you have to fabricate them?
Cheers _________________ '76 bay going superfly TDI |
Posted: Tue Sep 05, 2006 9:51 pm Post subject: |
hi - since jace has very limited access and ive done a fair bit on his bus ill try to help....
originally jase ran a carbed passat engine before the gti (whichwas from a scirocco).
16v/8v makes no odds really both willfit.
Jace bought his adaptor but i dont know where from...he is still considering using the t25 housing on the bay box....this is talked about here... http://www.vwkd.co.uk/bb/viewtopic.php?t=59
the angle will be determined by the bellhousing which bolts in place of your bay B/H
the general fitting process is the same for any conversion ...basically I did as you say - mate the whole unit with box up and bolted into van supported on stands then worked around it. I used a isngle bar for my scoob but I know jace ha a ladder bar set up - but design is all up to you really - its not too hectic at all.
Afraid I dont know about the t25 mounts to bay chassis |
Posted: Wed Sep 06, 2006 6:59 am Post subject: |
Cheers Rich..
I Better start looking for a 16v motor and a t25 to rip apart then!! _________________ '76 bay going superfly TDI |
Posted: Wed Sep 06, 2006 11:44 am Post subject: |
its rumoured that jace will be at vanfest in his van on sunday tbc....im sure he would be only too happy to give you a tour...
Rich |
Posted: Thu Sep 07, 2006 8:28 am Post subject: |
The mighty one wont let me go..( to much money..nag nag )
( you spend the first 15-19 years getting nagged at by your parents, then you get married )
Cheers for your help rich ( even though it's all your fault!!! saw your reply on the 2.2 scooby t25 on jk and your link to this site!!!! ) _________________ '76 bay going superfly TDI |
