rusty69bus Jedi Master
Alex (FTS) Jedi Guardian
Posted: Thu Mar 01, 2007 6:36 pm Post subject: |
Those 288mm disc's look like G60 disc's. That my plan to fit G60 discs and calipers onto my bay-very usefull to see there kits. I'm doing mine to a bay so a bit differant but hopefully not too much. Good find  _________________ www.faltownskateboards.com |
doppelganger Jedi Guardian
Posted: Thu Mar 01, 2007 7:39 pm Post subject: |
audi a6 discs and he is doing a kit for bays and working on rears for t25 at the mo  _________________ vwdrc class rep
Posted: Fri Mar 02, 2007 10:49 am Post subject: |
| didn't notice kit for bays,i have another look |
Posted: Fri Mar 02, 2007 9:57 pm Post subject: |
i dont think they are on the site but talking to dave he is looking into it  _________________ vwdrc class rep
futbus Initiate Jedi
Posted: Wed Mar 14, 2007 7:22 pm Post subject: |
I am looking into bays for brake upgrades. Early T25`s i believe are the same as later bays, in which case this kit will fit. Early bays looking at getting an upright so I can look at early and splits for a big disc conversion. Not all that we do is on the site although we try to add most things as we do them.
Any requests will be looked into, and at the moment seems to be bays, so watch this space.  _________________ www.futbus.com
Any machining needs give us a shout on 07866 581136
Located in south devon |
Posted: Sun Apr 29, 2007 5:56 pm Post subject: |
hi all, you guys may know the answer i'm fitting a4 wheels to my bus, do longer t25 studs fit bay (small 5) hubs :smt017 and where can i get them from brickwerks? _________________
Posted: Mon Apr 30, 2007 5:44 pm Post subject: |
Hi there t25 studs do fit but the spline pattern isn't exacly the same so I always tack weld them in to be safe. As far as I know there arn't any other studs that fit better. You can get them from demon tweeks though. _________________ www.faltownskateboards.com |
Posted: Tue May 01, 2007 7:27 am Post subject: |
JP used bay rear studs at the front as they are longer...you jut need to machine / grind off a little of the spline where it pokes thru a bit far.
On the back i think he used the OG studs as they were ok in length. |
Posted: Tue May 01, 2007 8:41 am Post subject: |
cheers i'll check the bay studs first ;) _________________
pugvan Initiate Jedi
Posted: Wed May 02, 2007 1:17 am Post subject: . |
[quote="richbaker78"]JP used bay rear studs at the front as they are longer...you jut need to machine / grind off a little of the spline where it pokes thru a bit far.
On the back i think he used the OG studs as they were ok in length.[/qu ote]
I think its the other way round ie bay front studs used for the back and new longer studs for the front.
(standard front studs are longer than standerd rear studs ) |
Posted: Wed May 02, 2007 8:39 am Post subject: |
| covin will be able to confirm as he had JPs old wheels and studs. |
