coolant and gaz sytem
1303RSII
PostPosted: Sat Mar 10, 2007 9:35 pm    Post subject: coolant and gaz sytem Reply with quote
hello,
i' m making the adaptation of an EJ20T WRX 2004 impreza, and unfortunally, i don't have the original expansion bottle of the engine (the one in metal fix on the engine)
so i'm asking you help, i try find the schema of the coolant system for know how i can adapt other expansion bottle...
i m tryng find the schema too of the gaz system, because i think have valve on the lines, but i don' thave, so i need be sure of it...
thanks
fred
ricola
PostPosted: Sun Mar 11, 2007 10:19 am    Post subject: Reply with quote
Steve Carter has a pic of the coolant system on his page:
http://www.clubvw.org.au/steve_carter.htm
Not sure what you mean by Gaz system?
Rich
http://www.ricola.co.uk
1303RSII
PostPosted: Sun Mar 11, 2007 10:20 am    Post subject: Reply with quote
thanks i m going to look now...
fuel system is more appropriate...?
1303RSII
PostPosted: Sun Mar 11, 2007 10:28 am    Post subject: Reply with quote
i just found: number 10 and 4 are fuel damper... is what i was trying find... but i found in STi documentation... is it the same for the WRX...?
