atschool Initiate Jedi
Posted: Sat Sep 09, 2017 5:24 pm Post subject: VW splitscreen tdi unfinished project |
Sadly I need to make some space so my splitty Betty needs to move on to pastures new. It is a Brazilian bus 1974 not yet registered in the uk. I did send all the paper work to the dvla and they sent it back because I did not send the correct cheque for road tax. It’s now tax exempt by the time the paper work came back from them the mot was about up so I decide to wait. It has a 1.9 tdi with a Audi flip box so 5 speed goes in all gears kit supplied by ultimate engineering (NOT YET RUNNING ) it needs the wiring sorting out full audi loom in the back with keys , I got it to the point of turning over two years ago. I drove the car home so I know its a good engine and box. Very easy to put back to vw power the flip box and engine set up is worth the cost of a vdub engine
It’s got new bay drive shafts and IRS fitted with all new back brakes & new front supplied.
4 to 5 stud adaptors on the rear to keep the 5 wide wheels
All doors are good and solid no filler & minimal rust including the barn doors
The rear back corners are solid
The flooring and rails are all good need minimal work all sills are good they have been replaced at some time in its life.
Comes with New A post for both sides need fitting
New 3 part B post for offside
Drivers side wheel arch panel new
4” lowered & narrowed front beam with sway ways fitted & drop spindles
Suzuki van steering rack fitted with so now rhd will need work only fitted to steer off drive.
Brand new race alloy radiator and twin fans
All glass including corners should you want to put them back in removed to weld up. (Because I wanted to)
full set of Pop out side windows they need new glass but frames are like new just need paint.
There is loads more but it’s been under cover two years so I cannot remember everything.It dose roll easy but my drive is gravel so a long winch would be best. I will not part the van out its all or nothing .Check out my other items I will be listing more car part’s.
for more info and photos of some of the parts copy and paste this link http://s1176.photobucket.com/user/andysharrock/library/andys%20vdub
Or try this link for photos https://tinyurl.com/y8aonk9h
now on ebay 122695940752 _________________ the weekends are never long enough |
Wilfred Darth Admin
Posted: Sun Sep 10, 2017 10:02 pm Post subject: |
sorry to hear this. If you were anywhere near, I would buy it for sure. This Is just my cup of tea! _________________ 1973 BayWindow running 1.9 110 bhp TDI with flipped gearbox. |
Posted: Mon Sep 11, 2017 8:54 pm Post subject: |
thanks Wilfred
I have put a lot of time and a lot of cash into the bus would be good to see it took on by someone that will Finnish it next time . andy _________________ the weekends are never long enough |
Wilfred Darth Admin
Posted: Tue Sep 12, 2017 5:51 am Post subject: |
how much would you want for it? _________________ 1973 BayWindow running 1.9 110 bhp TDI with flipped gearbox. |
Posted: Tue Sep 12, 2017 6:21 pm Post subject: |
I have got it on ebay for £6,500 I paid more for it and spent about £1500 on it and countless hours there is also £1500 worth of two new A and b posts to go with it . around the 6k mark
ebay item number 122695940752 _________________ the weekends are never long enough |
Posted: Wed Sep 20, 2017 10:30 am Post subject: |
That's gutting dude that will be an awesome bus.. if I had the cash I'd def buy it.
So what will you let it go for mate? and how much for the TDI and flip box parts?
Best of luck with the sale  _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
2013 Scirocco TDI GT |
