panel Jedi Knight
Joined: 24 Jul 2012 Posts: 133 Location: Victoria,B.C. Canada
Posted: Sat Aug 06, 2016 4:30 am Post subject: MAF scaling ? |
Have any of you that have done a Subaru conversion done any MAF scaling after you've put in a different intake/inlet pipe ?
I was told that every modification you make on the intake pre and post MAF will change the airflow metering, so you'll need a new MAF scaling. _________________ EJ20 Turbo bus build |
