Posted: Thu Mar 24, 2016 7:37 pm Post subject: Subaru engine from automatic donor car
Hi,
sorry if this has been posted elsewhere but if so I havent found it. I have found a low mileage (1995, 56.5K) car from which I would like to use the engine etc. However it is an automatic and I am unsure if the input shaft is different from a manual and if I can use the engine.
Will the ECU, loom and flywheel be ok, or would I be better off sourcing a manual car from the start. The mileage would appear to be correct so would hate to waste a good local source. I was looking to get bellhousing et all from RJES.
Auto will be fine. You just change the flywheel. As for harness I've done a few auto ones you won't have a problem. Give me a shout if you want the harness doing
