Posted: Wed Mar 09, 2016 2:31 pm Post subject: Material for adapter plates?
Am I right in thinking that Mild steel will be strong enough?
Looking at 25mm thickness, but wondered if there was a spec on the type steel needed at all?
I know if it was to be aluminium it would need to be T6 for strength?
Luckily I found a supplier who can provide rings cnc plasma cut to size, so I can make an MDF template, get them to cut me a ring and I cant drill holes to suit! _________________ Second Gear All The Way Baby!
