Gauge Questions
czm
PostPosted: Mon Nov 02, 2015 1:55 pm    Post subject: Gauge Questions Reply with quote
Hi there
I am getting everything ready for my Ej25 conversion in my T25.
Just finishing of the rebuild of heads ect.
One point I have yet to think about is the qauges/readings.
Currently I have the stock standard T25 cluster which has the temp/fuel level on the right and the speedo on the left - thats it.
So what are my options?
Do I add after market gauges to monitor other info and if so what?
Do I change/modify the current cluster?
Any help guidance would be appreciated
PostPosted: Sat Nov 07, 2015 10:23 pm    Post subject: Reply with quote
Use your t25 temperature sender and stick it in place of the Subaru temperature gauge sender.
Simples.
You'll have to use an after market boost gauge for when you fit the turbo.
