What AMP fuses needed JDM motor MY99-00 V5-V6 EJ20T
panel
PostPosted: Sun Oct 25, 2015 2:51 am    Post subject: What AMP fuses needed JDM motor MY99-00 V5-V6 EJ20T Reply with quote
Hey guys , just need some idea of what amp fuses belonged in these spaces?
Motor is from a JDM MY99-00 V5-V6 EJ20 Turbo Forester.
EJ20 Turbo bus build
PostPosted: Tue Oct 27, 2015 9:54 pm    Post subject: Reply with quote
Not sure if your running yet. I too wonder this after finishing my conversion. I fitted low amp fuses and waited until the popped. Then up' them by one step. Not the most accurate way but all is running well now Happy
panel
PostPosted: Sat Oct 31, 2015 5:05 am    Post subject: Reply with quote
Might have to try it that way , thx.
VW_Kraft_Dinner
PostPosted: Sat Oct 31, 2015 7:55 pm    Post subject: Reply with quote
Did 15, 30, 15, NA, 15 not work out for you?
panel
PostPosted: Tue Nov 17, 2015 2:43 pm    Post subject: Reply with quote
I haven't got the bus running yet to tell and I had no idea what to use as a starting point.
PostPosted: Tue Nov 17, 2015 3:44 pm    Post subject: Reply with quote
The diameter of the wires connected to the fuses give a good indication, right?
I would use that just to get an estimate.
panel
PostPosted: Wed Nov 18, 2015 2:15 am    Post subject: Reply with quote
Rule of thumb for diameter to fuse ratio is ?
PostPosted: Wed Nov 18, 2015 7:50 am    Post subject: Reply with quote
It is in dutch, but I think you get the point:
This diagram gives the maximum amperage a wire can handle. Select the fuse accordingly! (of course the fuse should be just a bit lower in ampere than the wire, otherwise the wire will become the weakest point....)
panel
PostPosted: Thu Nov 19, 2015 1:50 am    Post subject: Reply with quote
thx!
