SCOO-BAY-BLUE Wannabe
Joined: 05 Oct 2015 Posts: 5 Location: Buckinghamshire
Posted: Sun Oct 11, 2015 6:14 pm Post subject: Subaru Fuel pump in Bay fuel tank |
Hi, I have a 1974 VW Bay 1800 cc type 4 that I am converting to run a ej22 2.2l N/A Subaru engine.1998
As I have the fuel pump already could I convert the bay tank or would there be any known problems ?
I'm sure I saw a photo somewhere on a website but forgot to save it . |
Wilfred Darth Admin
Posted: Fri Oct 16, 2015 9:11 pm Post subject: |
Yes either weld the Subaru fuel pump into the top of the bay tank or modify the bay tank to have a 12mm outlet feeding a Bosch 044 pump. _________________ Think......
1303Steve Jedi Knight
Joined: 07 Aug 2009 Posts: 208 Location: Sydney, Australia
Posted: Sat Oct 17, 2015 8:11 am Post subject: |
Hi
Didn't you get late bays with EFI where you are? You could just use a tank from one of them, they used an external pump but had a return line and built in surge section?
Steve _________________ STI powered 1303 now running
G50 box, Boxster/944 brakes, Adaptronic 1280E ecu, PWR intercooler etc |
VW_Kraft_Dinner Force Sensitive
Posted: Wed Nov 18, 2015 6:51 pm Post subject: |
| Kai wrote: | | Yes either weld the Subaru fuel pump into the top of the bay tank or modify the bay tank to have a 12mm outlet feeding a Bosch 044 pump. |
What's the reason that the outlet needs to be 12mm when the Subaru supply line is 8mm? |
