1Kingy79 Initiate Jedi
Posted: Thu Aug 06, 2015 7:06 pm Post subject: Subaru Harness |
If anyone is struggling with their harness and is looking for someone to make them one give me a shout
Based in the midlands |
pressy4pie Wannabe
Posted: Wed Aug 19, 2015 1:57 am Post subject: |
I have mine all set up, but i just have a few questions i want to check before i try to plug it all in.
i have a us 98 legacy engine and harness. my engine has three plugs on it which i have all wired up, except theres a green and a purple wire coming from the biggest plug. i think these are water and oil pressure yeah? so those just go to gauges right?
also on my main (brown) relay i have one yellow wire with a blue stripe and another yellow wire with a red stripe? i ran the yellow/blue one too pins 1-2 on the ecu and the other one i have going to the fuel pump relay. i just matched the color and would like to know if this is correct?
last thing is i dont have any other connectors i dont think. just the three engine plugs, maf, o2 sensors(2) and ignitor in the main enigne loom. do i need a diode or something? i cut out a brown connector that people seem to be keeping but im not sure what it is? |
Posted: Wed Aug 19, 2015 9:51 pm Post subject: |
Hi firstly if you have cut out the 16pin brown connector you will have serious issues. You have ignition feeds main earth points and also all wire for your injectors in there.
Is this the first plug you have cut? |
pressy4pie Wannabe
Posted: Thu Aug 20, 2015 3:16 am Post subject: |
no its not the 16 pin one. i dont have a 16 pin brown connector. its a two pin connector labeled "Pressure sources switching
solenoid valve"
i have three grey engine plugs, the maf, the ignitor and 2 o2 sensors. |
