clutching at straws . . .
bug12345
PostPosted: Tue Aug 25, 2015 4:32 pm    Post subject: clutching at straws . . . Reply with quote
like the title says - clutch related problem
i have a karmann ghia with a n/a 2 litre lump
however, the clutch does not fully disengage - and slips
i fitted a bus clutch arm - beefier to keep up with the stage 1 kennedy clutch
the fingers of the clutch appear not to bend inwards when the clutch plate is tightened on the flywheel , hence the clearance issues and the as a consequence the clutch slipping ?
any ideas, without taking out the engine again?
it is a ds tuning adapter plate - should it have the standard bus clutch at 215mm?
your help will be much appreciated
