subaru loom question
atlas2l8v
PostPosted: Sun Aug 23, 2015 7:54 pm    Post subject: subaru loom question Reply with quote
managed to take the full loom out the car (excluding the rear looms until tomorrow) and im going through checking what each module does to see if i need it. (Car ive took it from is a 2.5l Auto legacy)
Ive come across the following and before i cut them out want to check if they are needed.
1) 2nr Modules related to the Keyless entry/alarm (Part refs 88205AE000
2) Acceleration sensor Part ref 27542AE000
3) Brown Plug and Brown Relay 25229AA030 (I think this is the ignition relay which i need to keep)
Cheers all
pressy4pie
PostPosted: Fri Aug 28, 2015 3:46 am    Post subject: Reply with quote
It depends on the year. i dont know much about post 1999. phase 2 is the easiest to me. and i have lots of wiring diagrams if you need them.
VW_Kraft_Dinner
PostPosted: Wed Oct 21, 2015 10:31 pm    Post subject: Reply with quote
Square brown one will be the main relay (which you do want to keep), starter relay (ignition) is square blue. I don't have the other 2.
