Wiring question
panel
PostPosted: Fri Jan 30, 2015 4:01 am    Post subject: Wiring question Reply with quote
I have this 4 wire connector on the engine side right on the motor harness.
Any ideas what it is? (JDM EJ20T 2000 Forester)
EJ20 Turbo bus build
panel
PostPosted: Sat Feb 07, 2015 2:51 am    Post subject: Reply with quote
Found it. It was the coil pack.
Now what is this one for?
panel
PostPosted: Thu Feb 12, 2015 6:02 am    Post subject: Reply with quote
OK.....here's my latest question.
What do those circled letters represent? Where does that wire go?
Examples:H ,I ,G ,F ,E ,C etc?
busyguyfish
PostPosted: Thu Feb 12, 2015 6:39 am    Post subject: Reply with quote
On one of the other pages of circuits you'll find the match up letter (F goes to F) etc. that looks like a really good link. how do I find it??
Thanks, Steve
Been there, Done that, and still enjoying life
I can't believe I turn 70 this month!! how did that happen
My first Vw van engine swap- Corvair with a power glide 1967. 48 years ago!!!!! I've got to grow up
panel
PostPosted: Sat Feb 14, 2015 1:56 am    Post subject: Reply with quote
The link to the wiring schematic? What year car/ECU etc ?
PostPosted: Sat Feb 14, 2015 11:41 am    Post subject: Reply with quote
Usually typing in your donar vehicle details along with Subaru service manual pdf should bring up good results. Takes some searching though. There are plentyful sources for early Classic (phase 1) Impreza's. I've found the equavilent for the facelift Impreza (phase 1.5).
But your looking for the genuine Subaru service manuals.
As busyguyfish said the circled F is a key to another part of the wiring schematic.
Panel are you doing your loom right now?
PostPosted: Sat Feb 14, 2015 5:01 pm    Post subject: Reply with quote
Here you go
http://ken-gilbert.com/impreza-manuals
PostPosted: Sat Feb 14, 2015 5:22 pm    Post subject: Reply with quote
2000 turbo forester right?
panel
PostPosted: Sun Feb 15, 2015 7:05 am    Post subject: Reply with quote
Not actually right at the moment but just preparing. I need:
small fuse panel
1 wire off the MAF to wire
2 off of each turbo sensor to wire
FP relay to wire up
Main relay to also wire up
Other than that it was not cut to much.
The main loom under the manifold is intact so all the wires from there go to:
Looks to be a JDM Forester Turbo MY99-00, so a V5-V6 ECU.
So I just have to go from there to these 2 which are just pig tails right now.
I'm also using this as my diagram at the end of the PossumLink manual (a scan of the OEM diagrams):
http://www.northursalia.com/modifications/misc/wiring/link5.pdf
PostPosted: Mon Feb 23, 2015 6:13 am    Post subject: Reply with quote
Sounds like a uber challenge. I'm lazy. I would just gone and pulled a replacement loom from another vehicle as then your pretty much just chopping plugs rather then joining them back together. Well done though Wink
Brignac
PostPosted: Thu Jun 18, 2015 2:39 am    Post subject: Reply with quote
As the new guy I am not attempting to hack your thread just didnt want to start a new thread with a similar title.
I am installing a 93 legacy ej22 na motor into a 69 beetle. I pulled the entire loom out of a junk yard car plug for plug with the exception of the portion going to the back of the car and i cut the wires at the legacy fuse box. Brought it home and started hacking.
I cut out the big grey 10mm plug but soldered each wire back. I'm going to be honest here and say I dont know what any wire does other than what goes to the obvious fuel pump relay, main ignition relay, maf sensor, 2 grey engine connectors, alternator plugs, 3 diagnostic plugs, and green ecu plugs.
I dont know which wires to use for the fuel pump, oil light, temp light, fans, etc..... Any help would be appreciated!
1969 STD BEETLE -Under Ground up Restoration with the installation of a Subaru EJ22 engine.
2001 Dodge 2500 Cummins Diesel 4x4
