Phil_n Force Sensitive
Posted: Sun Apr 19, 2015 9:24 pm Post subject: EJ22 '72 Bay electrical gremlins! |
Evening everyone.
I'm having a bit of trouble with my EJ22 powered bay. Essentially it cut out on the motorway and now will not start.
When the ignition is switched on, the fans are constantly kicking off and on randomly as is the fuel pump and the relay. I've changed this, but with no success.
I'm pretty sure I'm getting fuel, but no spark.
Any ideas where to start would be welcomed!
Thanks in advance, Phil |
mackaymanx Initiate Jedi
Joined: 28 Oct 2011 Posts: 25 Location: Queensland,Australia
Posted: Sun Apr 19, 2015 9:52 pm Post subject: |
| Check your ignition switch is not starting to break down and give intermittent power to the ecu. |
Posted: Mon Apr 20, 2015 6:36 pm Post subject: |
I've got one ordered so will hopefully pop it in tomorrow.
I've also found out my alternator's goosed, so that's gone for a rebuild. |
Posted: Tue Apr 21, 2015 2:40 pm Post subject: |
What year engine? _________________ Think......
Posted: Tue Apr 21, 2015 5:20 pm Post subject: |
I've changed the switch and it's still the same.
I'm not sure on the year of the engine as the conversion was carried out a couple of owners ago. How would I go about finding this out?
Regards |
Posted: Tue Apr 21, 2015 5:33 pm Post subject: |
Coil pack location.
Number of plugs for the ecu. _________________ Think......
Posted: Tue Apr 21, 2015 5:34 pm Post subject: |
Sorry ej22 is early legacy I think
Nope. Legacy from 90-99
Impreza from 95-99
It's gonna be ecu plugs then. _________________ Think......
Posted: Tue Apr 21, 2015 5:48 pm Post subject: |
First thoughts, sounds like it's in test mode. However that's not random. Those things cycle over and over.
If it's a faulty ignition switch, it wouldn't randomly cycle the fans on and off. Fans are usually ecu controlled. Unless temp sensor is goosed, then they stay on. Only time the fans turn on then off is during test mode.
How are your fans wired and controlled?
Also goosed battery/alternator are capable of doing weird poo. _________________ Think......
Posted: Tue Apr 21, 2015 9:05 pm Post subject: |
The fans are wired off a temp switch as far as I'm aware. Currently they are tripping off and on when the ignitions on and the engine is not running though. I've shorted the power to these across the ignition relay plug and the same is occurring.
On another note the alternator is with a local repair shop who have told me it's knackered. Whilst it's been off the van Its exhibiting exactly the same symptoms. Hopefully this could be to blame. |
Posted: Wed Apr 22, 2015 6:17 am Post subject: |
Charge the battery _________________ Think......
Posted: Wed Apr 22, 2015 9:50 pm Post subject: |
The alternator is back on and all is not good! Exactly as before.
I've recorded a little clip here to illustrate what's going on.
http://youtu.be/mX9SbGTnifY |
Posted: Fri Apr 24, 2015 3:05 pm Post subject: |
Sounds fucked
How are your fans wired up?
Whats controlling the fans? ECU?
What is actually clicking? sounds like its a relay controlling the Fans thats clicking.
You should be able to hear the fuel pump priming the fuel system with the ignition going on.
Engine has wasted spark coil pack so post 1996/7 I believe. Also believe these should have the subaru immobilser also fitted.
I would be tempted to try bypassing the ignition switch feed to the subaru loom. is there a fuse for the main relay wiring? if so run a power cable to there and bypass all the ignition switch wiring.
also if your alternator was knackered then chances are the battery is not in such a good state. Try charging it and getting it tested. I spent a couple of days after finishing my conversion trying to get the fucker to start until I realized the battery was flat. _________________ Think......
