axeman Wannabe
Joined: 14 Mar 2014 Posts: 3 Location: United Kingdom
Posted: Wed Sep 24, 2014 2:40 pm Post subject: maf issue? |
hi all
i have a problem with our 1996 ej22 converted westy syncro and i am hoping that someone will be kind enough too help. i converted the from a jx using mostly rjes parts
since the conversion it has run very well as i expected, with one slight problem intermittently if you were coming to a stop it would stall, this was quite regularly, also if you were cruising on the motorway at any speed every 20 or 30 mins there would be a complete loss of power as if you have turned off the ignition. it would refire with in a second or 2 and continue on as normal untill it happened again.
to day i drove around 10miles parked at the shops and it would not restart. i did a diagnostic test (joined the black wires) and fault code 23 came up. (maf problem) now i had a spare maf the same part no but the terminals are differnt. and this did not work either.
in the end i had to diss the maf connection and got it running (very rough) and limped her home.
do any one have any thoughts on this.
many thanks neil |
jamiegolf Force Sensitive
Posted: Sun Sep 28, 2014 8:09 am Post subject: |
Very possibly for the maf to have died, have you tried spraying carb or brake cleaner through it to clean the internals? Does work sometimes, if not then a new maf is in order........ _________________ Vw t25 westfalia joker ( soon to be scooby 2.2 )
Vw mk1 jetta pd130 remapped to 195bhp
Vw t4 1.9 tdi ( wife's bus ) |
Posted: Wed Oct 22, 2014 9:17 pm Post subject: |
There is a crude test for a dodgy MAF sensor, can't exactly remember what it specifically was but with the engine running unplug the MAF. It will either continue to run or it'll die. I believe continue to run would indicate a muggered MAF as the ecu has learnt to run with the current poor MAF signal.
Also stalling at junctions isn't that a speed sensor fault indication? Although saying that if your only able to pull one code off then your ecu is happy with the speed senser signal it's receiving. _________________ Think......
