which temperature gauge for subaru
zed
PostPosted: Sat Aug 23, 2014 10:23 am    Post subject: which temperature gauge for subaru Reply with quote
Hi , finally taken the plunge & bought a 2.5 subaru to do the conversion to my air cooled t25 ,, what temperature gauges are you using as i want to get one that works correctly,i bought one for my old yank & it was rubbish it would never read correctly so thought i would ask here first ,thanks in advance
PostPosted: Sun Aug 24, 2014 6:26 pm    Post subject: Reply with quote
Buy a water cooled t25 gauge and matching sender. I used a different sender on my porsche gauges and it's too sensitive. I was told by a Subaru tuner that the Subaru gauge doesn't move away from the gauge centre position until it gets to 110 degrees Celsius. My gauge moves up and down all the time, makes you a little paranoid as it creeps up into the red every time the fans just want to kick in, soo, I've bought the matched sender for my gauge now and I'm hoping it'll be less sensitive.
zed
PostPosted: Mon Aug 25, 2014 5:28 pm    Post subject: Reply with quote
Hi thanks for that i may as well buy a set of watercooled clocks & a standard sender then , thanks again for your help i,m sure i'll have many more questions
Joel
PostPosted: Tue Sep 02, 2014 11:29 am    Post subject: Reply with quote
Kai wrote:
I was told by a Subaru tuner that the Subaru gauge doesn't move away from the gauge centre position until it gets to 110 degrees Celsius..
thats a pretty standard thing on Jap cars, my Mazda and Nissan are the same.
the static zone is 80 to 110c.
I hate that feature, by the time the gauge starts moving again at 110c you only have another 10c before they start boiling.
if its still going up after 100c they are starting to get hot.
