Can you look at your knock sensor and power steering wires.
ping
PostPosted: Mon Aug 11, 2014 7:54 am    Post subject: Can you look at your knock sensor and power steering wires. Reply with quote
I took my engine loom off thinking all plugs were different! Now I'm unsure which wire is to the knock sensor as the knock and ps have the same plugs!
Can you tell me what colour is on your engine loom going to the knock sensor please?
PostPosted: Wed Aug 20, 2014 5:32 am    Post subject: Reply with quote
Once you've chopped the loom, the knock senser will go to the ecu plugs, the ps wire would be left dangling once it's passed through one of the three large square engine harness plugs as you should no longer have the plugs for the dash gauges any longer.
ping
PostPosted: Wed Aug 20, 2014 6:31 am    Post subject: Reply with quote
Nice one. It all comes clear in the end.
