ping Jedi Master
Posted: Thu Oct 02, 2014 7:39 am Post subject: Iacv pipe advice please. |
| Where do you have your iacv pipe connected to? Does it have to go in it a resonator box or can it just go to the air intake pipe after the maf? |
Posted: Fri Oct 03, 2014 9:49 am Post subject: |
Just into the air intake pipe. _________________ Think......
ping Jedi Master
Posted: Fri Oct 03, 2014 11:55 am Post subject: |
| Cheers. I wasn't sure if it had to be a certain lengh or what not. |
Posted: Fri Oct 03, 2014 12:05 pm Post subject: |
No the idle control valve is basically a bypass to the throttle butterfly, basically it's a choke which is controlled by the ecu. Therefor it's only requirement is that it must use measured air after the MAF. _________________ Think......
ping Jedi Master
Posted: Fri Oct 03, 2014 12:37 pm Post subject: |
| Thanks Kai, my engine is starting to come together now, it's taking a while due to other projects tho! |
