Anyone done a hydraulic clutch!
ping
PostPosted: Tue Mar 18, 2014 1:16 pm    Post subject: Anyone done a hydraulic clutch! Reply with quote
I'm going to use the Rjes bell end to fit a scooby turbo motor in a 71 bay so looking to convert to hydraulic clutch as a must. Any one got any pics or links of this done. I'm looking to use t25 bits. [/list]
southcoastcruiser
PostPosted: Tue Mar 18, 2014 5:23 pm    Post subject: Reply with quote
t25 on the front and subaru on the gearbox
ping
PostPosted: Tue Mar 18, 2014 9:24 pm    Post subject: Reply with quote
Cool. Any pics of the conversion?
ping
PostPosted: Tue Mar 18, 2014 10:02 pm    Post subject: Reply with quote
Also why not use the subaru master?
ping
PostPosted: Wed Mar 26, 2014 8:36 pm    Post subject: Reply with quote
Silly question on the subaru master!!!
Still looking for info on the hydraulic set up!
PostPosted: Wed Mar 26, 2014 9:01 pm    Post subject: Reply with quote
is this for a type 1 box or the the bigger type 2 units?
hydraulic clutch's have been done loads on the type one and doesnt rjes sell a bracket to convert the type 2 (091) box to hydraulic clutch?
ping
PostPosted: Wed Mar 26, 2014 9:59 pm    Post subject: Reply with quote
Type 2 box but I'm more interested in the pedal end. Cheers.
PostPosted: Thu Mar 27, 2014 6:49 am    Post subject: Reply with quote
Righto, you can't use the Subaru one id imagine as you would want to have a remote reservoir to fill it up.
I can't remember what size you would want at the minute. Either 0.700 or 0.750.
1303Steve
PostPosted: Sun Mar 30, 2014 9:05 am    Post subject: Reply with quote
A lot cars use a Tee from the brake master cylinder supply line to supply the clutch master cylinder
No need for a separate reservoir and you will run out of clutch fluid before running out of brake fluid if you have a fault in the clutch hydraulics.
I would have thought mounting a clutch master cylinder would be pretty easy on a Type 2, I've only done it on Beetle
Steve
STI powered 1303 now running
Superleggo
PostPosted: Thu Apr 03, 2014 10:16 pm    Post subject: Reply with quote
Hi I think this is the link to my Hydraulic clutch mounting system.
It starts at the bottom of the page. Very simple. I think Rich Baker is running a similar system.
http://vwkd.com/bb/viewtopic.php?t=3525&postdays=0&postorder=asc&start=96
I hope it helps. I used a MK3 Land Rover unit only because it matched the original diameter of the Mondeo system I am using and they are very cheap.
There are lots more variations of diameter on the land rover unit. I think mine was 0.75'' 19mm
ping
PostPosted: Tue Apr 08, 2014 12:30 pm    Post subject: Reply with quote
Lovely, thanks for sharing that, i had a look at your build thread and it looks good,
