easy-does-it Jedi Guardian
Posted: Mon Nov 04, 2013 7:35 pm Post subject: Porsche Boxster gearbox .. bus flip conversion |
Yep it's from a boxster... uncannily the same casing as the audi/passat box used for the flip conversion.. I only bought it as i was after the cables and brackets and bits that came with it.
Code is..
83,000 miles on it
£120.
AND.. if you want it for a flip conversion for an extra 30 i can router it down the 15mm if you wish.
collection is from Alconbury ( nr Huntingdon/Peterborough) _________________ '76 bay going superfly TDI |
Superleggo Jedi Master
Posted: Wed Nov 13, 2013 10:11 pm Post subject: |
| I have just bought a new toy in the form of a boxster S. When I was reading up on Boxsters before I bought one I read somewhere that the boxster box and the 911 box were the same except that they flipped the diff. Hence it may be possible to dismantle and build it into a 911 box to save running it upside down. Just a thought. |
