Subaru calipers/sharan disc's
popout
PostPosted: Thu Nov 14, 2013 8:39 am    Post subject: Subaru calipers/sharan disc's Reply with quote
Ive read posts about using Legacy front calipers and Sharan disc's as a cheap front brake upgrade. Does it have to be Legacy calipers or ones from Impreza etc the same?
Do I need the 4 pots?
or 2 pots?
I know I need to make mounting brackets for them. Has anyone any pics of them fitted to a Baywindow?
Cheers Tim
popout
PostPosted: Thu Jan 01, 2015 10:28 am    Post subject: Reply with quote
Done this with not too much hassle, used 400mm x 20mm steel bar. Had to grind out a bit on the back in the middle as the face on the spindle isn't flat, but simple enough. Sink the bolts holding the bracket to the callipers and tap the bracket to bolt to the spindle using the original calliper bolt holes. Used the callipers of the Forester and 288mm vented discs for a vw Sharan
trev
PostPosted: Thu Jan 01, 2015 11:56 am    Post subject: Reply with quote
thanks for sharing Popout Happy
did the Sharan disks go straight on in place of the bay window fronts?
popout
PostPosted: Thu Jan 01, 2015 12:17 pm    Post subject: Reply with quote
yes, but the sharan discs really need the 2 locating bolts so need the drill the hub for the second. I'll take some pics tomorrow. Had to use 16" wheels to clear the callipers, some 15" may fit but thought it was a bit tight. Using the Forester hoses too, there's 2 joined together so long enough to go from calliper to the hard brake pipe.
trev
PostPosted: Thu Jan 01, 2015 7:15 pm    Post subject: Reply with quote
look forward to the pics, thanks
popout
PostPosted: Fri Jan 02, 2015 1:47 pm    Post subject: Reply with quote
trev
PostPosted: Fri Jan 02, 2015 3:53 pm    Post subject: Reply with quote
that's a lot of disk!! Is the whole pad touching the disk?
popout
PostPosted: Fri Jan 02, 2015 5:14 pm    Post subject: Reply with quote
Not sure what you mean, how can the whole pad not be touching the disc?
As for disc being big, its the only one that's right for diameter/height/ 5x112/center bore size to fit the Subaru calipers on the bay spindle
trev
PostPosted: Sat Jan 03, 2015 11:22 am    Post subject: Reply with quote
oh, wait, is there no pad fitted in the photo you put up? That might explain why it looks unusual to me!
popout
PostPosted: Sat Jan 03, 2015 11:49 am    Post subject: Reply with quote
Ah yeah, no pads fitted Wink
popout
PostPosted: Sun Jan 11, 2015 8:01 am    Post subject: Reply with quote
With the pads fitted Wink
