Syncro16 Wannabe
Posted: Sun Nov 03, 2013 9:28 pm Post subject: T3 (T25 Type 25) 1.9D engine and 3H 5 speed gearbox |
1.9D (AEF, same as the 1Y or an AAZ without turbo) 65bhp engine (JX is only 5bhp more), fitted with all original T3 diesel parts and fitted to a 3H 5 speed gearbox all in great condition.
This engine and gearbox are currently bolted into my 1990 Tristar 2WD Doka and I'm driving it daily. You can drive the van to check everything.
I'm getting 35mpg regularly. The engine has done 110k. I fitted a new timing belt and tensioner to it at 100k and have just serviced it at 110k.
You are buying the complete engine with all ancillaries, that is...
Engine
Flywheel/clutch (JX)
Sump (T3)
Engine bars and mounts (T3)
All cooling system pipes in the engine bay and header tank
All wiring to make it run
Exhaust system
Gearbox (5 speed, 4.83 with .82 5th - there's only one higher ratio gearbox available so it's good for cruising etc)
T3 diesel bellhousing and input shaft
T3 diesel mounting bracket and shift rod (rear section)
The lot... ready to bolt into your van. Ideal for converting a petrol T3 van to diesel or just sell off the parts that you don't need if you already have a diesel.
This engine could also be converted easily to AAZ spec with the turbo/manifold and diesel pump from an AAZ.
Only for sale as I'm carrying out another engine conversion on the van. I've done 10k with this engine in my van with no problems. I fitted new glow plugs, thermostat etc when I fitted it into my van, so it'll be reliable for a while yet
You could also use all of the above parts minus the base engine to fit a 1.8 8V or 2.0 8V engine into your T3. All of the parts swap over
£1350.00 bargain price. The parts in this lot are worth a lot more.
Available now. Collection from Leeds, West Yorkshire. Test drive can be in Banbury or Leeds.
syncros8@gmail.com
07989 333437
MG |
