Posted: Sat Mar 30, 2013 8:32 pm Post subject: richs garage clearout
hi all - im having a spring clean in the garage - the following items are up for sale - all prices negotiable
early bay bumper irons £50 ono
late bay front brake discs and calipers with backing plates £80 (one caliper is t25 but still fits exactly the same) used but working order - for sale due to upgrade
Remote servo kit with master cylinder (as used in MGs and the like but was fitted to mates bay and was very effective) £20
t25 expansion tank £5 / 2x Porsche centre caps from teledials I think £5
Brand new bilge pump from a boat - 12v and high flow. Never used - I was going to use for my chargecooler but could be used as an auxiliary electric water pump in engine circuit- its about 10 inches or so long and flows a lot of water! £40
Fusion speakers - £5 I think I have the mesh covers somewhere too but don't count on it
Hitachi battery drill - with 2 batterys - great little drill (no hammer though) batterys are usable but you need to keep em charged up £25
Eberspacher d5w diesel water heater - as fitted in BT vans - great engine preheater or way of running hot water, heating radiators or using your in car fans to blow air as a night heater- working when removed - needs a fuel pump to run (available on ebay), plus a switch. Has ecu, loom, fuse box £60
Transporter t5 bulkhead (removed from 2008 t5 - £20
Double glazed units - ideal for a garage or even house - I have 2 like this - the other is the mirror image (opener on other side) £15 each. measurements on request.
hobbymat md65 lathe - all working but missing a gib strip (strip of metal from the middle adjuster) this could be made by a machine shop for £10-20 to make a great little hobby lathe. comes with book, some tools, gear set, and emergency cut out. £100
Much of this (windows, lathe ) is unpostable but im happy to send out the smaller items but please be patient. Collection is also possible from SN148BS near Bath or if you live between bath and Lancaster I will be making this trip in a couple of weekends time and am happy to meet at motorway services / junction enroute.
