How much weight can type 1 gearboxes support?
Baz
PostPosted: Tue Mar 19, 2013 12:00 am    Post subject: How much weight can type 1 gearboxes support? Reply with quote
Hi guys,
Sorry to make my first post a question (and also sorry if it is in the wrong section, I couldn't decide where to put it). I'm currently converting my beach buggy to WC, the engine I'm fitting is quite a bit heavier (around 250kg), whilst I'm in the process of fabricating the engine support is it ok to have that sort of weight hanging off of the gearbox? Engine won't be started, but I'm not sure whether just having it hanging there on just the gearbox mounts could crack the gearbox.
Thanks in advance, pictures will be put up soon Grin
tuzza123
PostPosted: Wed Mar 20, 2013 4:32 pm    Post subject: How much weight can type 1 gearboxes support? Reply with quote
Hi Baz
Some people hang all type of motors off just the 4 bell housing bolts
My only advice is when you do start to fabricate your support support the box a little so the front mount is not under tension .
Hope that is clear. Cheers
Baz
PostPosted: Wed Mar 20, 2013 8:22 pm    Post subject: Reply with quote
Cheers for the reassurance! I'm not far from you, just up the road in Trentham, Stoke. Got any more pics of your ride?
tuzza123
PostPosted: Thu Mar 21, 2013 10:10 am    Post subject: CAMPER BUILD WITH 2.2 SUBARU ENGINE AND GEARBOX Reply with quote
Here you go
http://www.photobox.co.uk/album/1773125298
Baz
PostPosted: Fri Mar 22, 2013 12:08 pm    Post subject: Reply with quote
Looks like a nice clean conversion, great job! Grin
