can i fit a T3 gearbox code Dk into my 77 bay? HOW??
simon1291
PostPosted: Mon Sep 10, 2012 8:33 am    Post subject: can i fit a T3 gearbox code Dk into my 77 bay? HOW?? Reply with quote
How do i fit the dk box into my bay? its the side selection type and i've got the original 1.6 box can i just change the nose cones? what about the mounts? i can get my hands on the dk box for £250 but just want to check i can fit it!
autoinnovations-kempston.co.uk
autoinnovationscampervanhire Facebook.
PostPosted: Mon Sep 10, 2012 6:01 pm    Post subject: Reply with quote
I've got a modified DK box in mine. After trying to work out a way of using the Dk linkage and failing i looked into changing the nose cone. It's not as easy as you think and ended up sending it to Bears motorsport for the conversion ( then got carried away and had longer ratio's added ...
simon1291
PostPosted: Mon Sep 10, 2012 8:13 pm    Post subject: Reply with quote
Cheers! I think I'll get in touch with them first thing in the morn I'll keep you posted.
simon1291
PostPosted: Sat Sep 15, 2012 8:59 am    Post subject: Reply with quote
Plan b! If i got a dk box could i swap the ring and pinion into my box?
Its a 77 1600 with 022 and 091 near the nose cone bolts.
simon1291
PostPosted: Sat Sep 15, 2012 9:14 pm    Post subject: Reply with quote
So I've brought a 091 box from a f reg t3 I'm hoping to change the final drive with mine to get taller gears? Anyone done this?
