crocodilemickdundee Wannabe
Posted: Wed Aug 29, 2012 6:25 pm Post subject: Power Steering |
Hi people, Ive fitted a vauxhall astra steering rack fed with a citoen saxo pump, problem is when i fire it up the steering goes full righthand lock all by itself and its a nightmare to try and drive,it goes all over the place, any ideas as to cause and remedy please.  _________________ With a DUB every day you learn something new! |
Obonobo Jedi Knight
Posted: Thu Aug 30, 2012 5:13 pm Post subject: |
No clue as to you problems, but I would like to see any pics of your build! _________________ Greetings from Sietze
And it's a long time since it looked anything like this! |
technipol Force Sensitive
Posted: Wed Nov 14, 2012 9:23 am Post subject: corsa "c" |
Best advice I can give is......
Start again with a Corsa "c" column and eletric pump and incorperate it into the original column so you can retain the ignition and keys - It works for me and did not cost alot, £50 for the column and pump and £40 for the "Brain" then half a days graft - SEEMPLES! |
