panel Jedi Knight
Joined: 24 Jul 2012 Posts: 133 Location: Victoria,B.C. Canada
Posted: Sat Aug 04, 2012 10:57 pm Post subject: Vanagon/Subaru flywheel in a Type 1 trans? |
Hey guys, I have a buddy that had been doing some Vanagon swaps and has a few aluminum adapters and flywheels made up. I borrowed a kit to see what it was all about and I tried the ally adapter up to a T1 trans and it looks all good.
My concern is the flywheel. What would be different in the Vanagon/Subaru flywheel compared to a T1/Subaru flywheel?
Are the pressure plate holes any different? I know that they are usually a 228mm but could I run a 220mm clutch and pressure plate with the Vanagon/Subaru flywheel? _________________ EJ20 Turbo bus build |
panel Jedi Knight
Obonobo Jedi Knight
Posted: Thu Aug 09, 2012 9:31 pm Post subject: |
I run a 091 6-rib T1 box with a EJ22 engine and RJES bellhouse. I use the biggest VW clutch plate, being the 228mm.
This works well: the splines of the box match the splines of the clutch plate, because they do so from the factory.
So as long as you use a clutch plate that is smaller than the original Subaru version ans had the same amount of splines as the original VW plates, you are good to go.
I am using the original pressure plate of Subaru, so no issues mating it to the flywheel. _________________ Greetings from Sietze
And it's a long time since it looked anything like this! |
panel Jedi Knight
Posted: Wed Aug 15, 2012 12:04 am Post subject: |
So I can run the 228mm Vanagon flywheel and use the 220mm Type 1 pressure plate/clutch combo in a Type 1 trans  _________________ EJ20 Turbo bus build |
