panel Jedi Knight
Joined: 24 Jul 2012 Posts: 133 Location: Victoria,B.C. Canada
Posted: Fri Jul 27, 2012 7:25 am Post subject: SubaruVanagon.com and his T-stat questions? |
I wondered why someone couldn't drill and tap into 'A' area or just run a 'T' from this hose I labeled 'B' ?
Posted: Fri Jul 27, 2012 9:58 pm Post subject: |
Or fit the water pump from a turbo engine with its two additional outlets.
Both your suggestions I would say are viable though _________________ Think......
panel Jedi Knight
Posted: Fri Jul 27, 2012 10:41 pm Post subject: |
What's that l@@k like? _________________ EJ20 Turbo bus build |
panel Jedi Knight
Posted: Fri Jul 27, 2012 10:44 pm Post subject: |
Forgot about Google Ok now what do you do about the other additional pipe. Cap it off?
Posted: Fri Jul 27, 2012 10:47 pm Post subject: |
| panel wrote: | Forgot about Google Ok now what do you do about the other additional pipe. Cap it off?
Yup _________________ Think......
Posted: Fri Jul 27, 2012 10:48 pm Post subject: |
Unless You wanna fit the oil cooler from the turbo engine _________________ Think......
panel Jedi Knight
Posted: Sat Jul 28, 2012 11:19 pm Post subject: |
Then is that the supply to the cooler or the return from the motor or ? _________________ EJ20 Turbo bus build |
Posted: Sun Jul 29, 2012 7:36 am Post subject: |
Can't remember but I'll have an educated guess that they are all returns. But the additional ports are for the oil cooler and the turbo. _________________ Think......
Posted: Sat Aug 04, 2012 1:07 am Post subject: |
*raises hand*
Can that be fitted to a 97/98 SOHC?
That pump would solve a fair few problems I'm running into ATM (shiny SS equal length header - butchered, ss bends, 2 boxes etc sitting between garage/front room/van)
& yes I bought the EJ20 stat cover (Subaruboxer mod), but it fouls the header _________________ The advice you receive on here is worth the paper it's written on.
Posted: Sat Aug 04, 2012 7:34 am Post subject: |
| ElusiveStranger wrote: | *raises hand*
& yes I bought the EJ20 stat cover (Subaruboxer mod), but it fouls the header |
Don't see why not, all the EJ blocks are the same
I paid 45 notes for a blueprint pump from my local motor factor. _________________ Think......
Posted: Sat Aug 04, 2012 10:08 am Post subject: |
Cheers Kai. Who's your local motor factor? I'm wondering if they're nationwide.
I might try Unipart if Paul_f's idea doesn't work. He's going to knock me up a spacer for the housing.
*walks off to play with shiny stuff, grinder and tig* _________________ The advice you receive on here is worth the paper it's written on.
Posted: Sat Aug 04, 2012 10:30 am Post subject: |
| ElusiveStranger wrote: | Cheers Kai. Who's your local motor factor? I'm wondering if they're nationwide.
*walks off to play with shiny stuff, grinder and tig* |
It's Camberley Auto factors.
Think I got a discount too, with the motor factors you can usually encourage a discount by telling them you have an account with (insert local garage name) and you wish to pay cash through that account. If they ask you for an order number just use (insert random alphanumeric combination), if you get rumbled tell them you need to make a phone call, phones in the car, then leg it, then send the mrs back after one hour and pay the full price.
N.B. I'm not condoaning this type of behaviour, also I've quoted this from another site. This tactic is to be used at your own peiral, I formally reject any form of responsibility or consequence. I offer no refunds either. _________________ Think......
