Error Code 24
splitbus67
PostPosted: Sun Sep 25, 2011 8:01 pm    Post subject: Error Code 24 Reply with quote
EJ20 99 NA Split - RJES Speed Sensor.
I'm getting error 24 when driving, it sounds like the problem that ElusiveStranger had in this post http://www.vwkd.co.uk/bb/viewtopic.php?t=2739&highlight=error+code, my problem is that I don't think my donor car had a neutral switch fitted, if it did i'm not sure how it was wired in, so I'm not sure what to check.
PostPosted: Sun Sep 25, 2011 8:08 pm    Post subject: Reply with quote
What's your symptoms?
Have you got 12V supplied to the VSS?
The NPS dodge is to just ground the wire that goes to the ECU. If the switch connector's still there, cut and bend a paper clip into a "U" and shove it in, the other side of the connector's earthed (very technical Wink )
splitbus67
PostPosted: Sun Sep 25, 2011 8:26 pm    Post subject: Reply with quote
Warning light comes on when I'm driving, if I slow down i.e. when I come to a junction the warning light goes out. Idle is OK, and it doesn't stall at junctions.
Yes, 12v supplied to the VSS, I hope, will check tomorrow
Not sure which wire the NPS is on the ECU, what wire colour is it?
Thanks
Phil
PostPosted: Mon Sep 26, 2011 12:01 am    Post subject: Reply with quote
16 pin connector, pin 9 - (bottom left). My wire is light green and yellow with a ring
Yours might be different
Joel
PostPosted: Wed Sep 28, 2011 3:24 am    Post subject: Reply with quote
Make sure your ECU is receiving a signal from the speed sensor still.
Mine did the exact same things when my VSS failed.
wasnt stalling but the light was coming on when coasting along with no throttle, would go out when stopped.
24 (idle control valve) is a common one that comes up when the speed sensor isn't working.
The computer thinks the ICV is faulty cos when you're rolling along with no throttle the ECU thinks the car isnt moving with no VSS signla but cant work out why the engine revs are still too high so thinks the ICV must be faulty.
hence the code 24.
splitbus67
PostPosted: Wed Oct 05, 2011 8:13 pm    Post subject: Reply with quote
Guys thanks for your help. I located the NPS connector, (two pin brown connector) with the other gearbox connections and shorted it out. Hopefully this will solve the problem if not I will have a look at the VSS.
Thanks
Phil
splitbus67
PostPosted: Sun Aug 12, 2012 7:09 am    Post subject: Reply with quote
My VSS problem seems to have returned.
How do you check that you're getting pulses to the ECU from the VSS, can you check it with a digital volt meter?
It's an RJES vss.
PostPosted: Sun Aug 19, 2012 9:41 pm    Post subject: Reply with quote
You can use a voltmeter* or a lamp (5V LED or a bulb). Led's the best option.
* Sometimes the good old analogue ones work better as you'll see the needle "twitch". A digital one may fail to react
splitbus67
PostPosted: Tue Aug 21, 2012 6:24 pm    Post subject: Reply with quote
I shall bring the AVO home from work Wink
Thanks
PostPosted: Wed Aug 22, 2012 7:56 pm    Post subject: Reply with quote
AVO's are good
Or borrow a 'scope
