407 Rear disk conversion..
graham-e
PostPosted: Sun Feb 13, 2011 11:53 pm    Post subject: 407 Rear disk conversion.. Reply with quote
Seen this on eBay...
http://cgi.ebay.co.uk/VW-camper-rear-disc-brake-conversion-kit-parts-/280628707710?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4156c6417e
So its basically a pair of 407 callipers some metal to make your own brackets and a pair of hubs?
What would I need to do to the hubs to fit mercedes sprinter disks with these callipers?
if anyone has any info i'd be grateful.. just i don't know where to start with something like this.
cheers!
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Mon Feb 14, 2011 12:00 am    Post subject: Reply with quote
At a guess I'd imagine the VW hub would sit inside the sprinter disc (they must be the same PCD).
Then drill the boiler plates to fit inplace of the vw drum's backing plate then bend/cut/weld/magic spell the boiler plate into the correct offset to place the caliper in the right place.
Make sense?
graham-e
PostPosted: Mon Feb 14, 2011 12:33 am    Post subject: Reply with quote
I've read the sprinter is 5x130, so i'm not sure..
I kinda understand what your saying but, I wouldn't know where to begin..
I just want to upgrade my brakes with out spending daft amounts of money, not sure how possible that is
PostPosted: Mon Feb 14, 2011 7:38 am    Post subject: Reply with quote
Just googled it and I'd agree that the sprinter is 5x130,
Perhaps the seller meant Merc Vito which is 5 x 112.
Look at the empi rear disc kit and you'll see the bracket I'm speaking off.
http://www.status-vw.co.uk/shop/en-gb/dept_211.html
Most kits are made this way, infact my Porsche 944 brakes are basically the same except the mount is much fancier as it incorporates the disc backing plate.
PostPosted: Mon Feb 14, 2011 7:39 am    Post subject: Reply with quote
Just googles it and I'd agree that the sprinter is 5x130,
redcamper
PostPosted: Mon Sep 17, 2012 3:39 pm    Post subject: Reply with quote
I used 2002 passat discs, had the rear hubs machined slighty to fit inside the discs, then used mk4 golf rear calipers.
is water cooled better than lawn mower no way tonto
