os rear hub problem
pmclok
PostPosted: Mon Aug 13, 2012 12:24 pm    Post subject: os rear hub problem Reply with quote
Mucho good advice needed..have a T25 subaru ej22 converted bu the rjes boys..my cv to hub bolts keep undoing themselves after I've torqued em up correctly!!!! Alls well for 20miles then there's starts to go slack when drive is taken up..have tried new hex bolts and new anti-slip washers!!!! All suggestions welcome Happy
Obonobo
PostPosted: Mon Aug 13, 2012 3:25 pm    Post subject: Reply with quote
Are you also using the two-holed plates (you need them on the transmission-side, 3 pieces, both left and right)? Just asking. And a drop of Loctite should help.
Greetings from Sietze
pmclok
PostPosted: Mon Aug 13, 2012 7:17 pm    Post subject: Reply with quote
hi yep will try ht bolts and loctight again!!!
PostPosted: Tue Aug 14, 2012 6:36 am    Post subject: Reply with quote
I'm under the impression that's these are stretch bolts and would definetly need replacing in your case. Pretty sure if you went and bought a quality cv boot kit it should come with new bolts.
