KARMAD Padawan
Joined: 26 May 2011 Posts: 78 Location: dublin ,ireland
Posted: Tue Aug 14, 2012 12:25 pm Post subject: Will this work ok? |
just wondering what you think. my ej20 has a map sensor and iacv on the air intake manifold, so no need for Maf sensor on the air filter.
Do you think i would have any problems if i mount the k&n close to the throttle body instead of having a bendy pipe?
SORRY ABOUT PICTURE CLARITY |
Ianbott Jedi Knight
Posted: Tue Aug 14, 2012 9:20 pm Post subject: |
| It won't work, your ecu needs the info from the MAF to work correctly, it is possible to run the newage turbos speed density ie using the MAP sensor. |
KARMAD Padawan
Posted: Tue Aug 14, 2012 9:32 pm Post subject: |
Im confused because the map sensor is on the air intake so i didn't think i needed a maf as well
you can see in the picture
[IMG]http://i1196.photobucket.com/albums/aa412/karmad76/littlegraham2008-1.jpg[/IMG
it a ej20 non turbo |
KARMAD Padawan
Posted: Tue Aug 14, 2012 9:40 pm Post subject: |
OOOPS  |
panel Jedi Knight
Joined: 24 Jul 2012 Posts: 133 Location: Victoria,B.C. Canada
Posted: Wed Aug 15, 2012 12:02 am Post subject: |
Still a newbie here but looks ok to me. What kind of intake to the TB did the OEM car have? I don't think you'll have a MAP and a MAF.
But I see Ianbott said....
| Quote: | | Not sure about the N/A but the turbo engines use a MAP and a MAF sensor. |
From this thread.....
http://vwkd.com/bb/viewtopic.php?t=4406 _________________ EJ20 Turbo bus build |
Joel Jedi Master
Posted: Wed Aug 15, 2012 12:28 pm Post subject: |
It's a MAP engine guys, it will be fine, just noisy. _________________ 1974 1303 Germanlook Suba-Beetle
