BlackCosmos Padawan
Posted: Fri Jul 13, 2012 8:41 am Post subject: DK 091 fitting nightmare..help!! |
| ok ive fitted a 091 box to my t25 89 and its all done apart from selecting gears..ive grafted the correct selector to my existing set up but still having problems..was a 5 speed before..was going to go cable shift route but no one does a kit for it at mo..has anyone upgraded to this box and had similar problems?? any help advice much apprieciated..my fitter has now given up asying it cant be done.. |
easy-does-it Jedi Guardian
Joined: 01 Sep 2006 Posts: 577 Location: cambridgeshire
Posted: Fri Jul 13, 2012 6:15 pm Post subject: |
Did you try and select all the gears before you put the box in the van?
Only ask cos i tried for ages getting one to fit in a baywindow only to find out a selector fork was broken so it was never going to work
If you need them ive still got the complete rod set up including shifter in the garage .. _________________ '76 bay going superfly TDI |
BlackCosmos Padawan
Posted: Sun Jul 15, 2012 7:43 am Post subject: |
| had a look at it today and it does go into some gears and drives..cant find reverse and seems to be inbetween neutral and a gear coz a bit grindy/noisey unless i hold gear stick forward a bit..is it just trial and error to set up selector or is there a way to do it easier?? |
