Turbo oil return pipe, what material is best?
easy-does-it
PostPosted: Tue Jun 12, 2012 1:32 pm    Post subject: Turbo oil return pipe, what material is best? Reply with quote
The rubber oil return hose ive been using keeps perishing, so i want to try a steel over braided hose. But which is better, steel over nitrile rubber or steel over PTFE.. or is there something else i should be looking at?
cheers Grin
'76 bay going superfly TDI
Ianbott
PostPosted: Wed Jun 13, 2012 12:36 pm    Post subject: Reply with quote
I'm personally using the standard Subaru one, can you not pick one up from subaru or eBay?
Thinking about it, do you monitor your oil temps as if they are consistany higher than standard then I'd imagine that will help with perishing the line.
easy-does-it
PostPosted: Wed Jun 13, 2012 6:44 pm    Post subject: Reply with quote
I can't use the standard one as i've relocated the turbo to the front of the engine as it's mounted in a camper..
sven
PostPosted: Thu Jun 14, 2012 1:23 pm    Post subject: Reply with quote
Hydraulic heat resistant hoses. I use them all the time.
Ianbott
PostPosted: Thu Jun 14, 2012 6:40 pm    Post subject: Reply with quote
Ah fair enough. As sven says, i would go to a hydraulic specialist like pirtec, they will give sound advise.
