ping Jedi Master
Posted: Wed Mar 26, 2014 8:42 pm Post subject: 71 bay turbo location? |
| Any suggestions on turbo location, i dont really want to move it but also i dont like the idea of having it under the fuel tank! Any ideas or idvice on moving the location with reguards to oil and water pipes etc greatly recieved. Also any thoughts on running without a intercooler as the turbo lawn mower motors tend to do? |
Posted: Wed Mar 26, 2014 8:59 pm Post subject: |
making a charge cooler is the best option, wither a legacy unit or toyota charge cooler would do. but dont forget your going to need apump and additional radiator.
im changing my charge cooler on my type three which i think would suit a tyoe 2 set up as it has a 180 bend to it.
reasonable priced units if you fancy making on.... courtesy of ricola
http://www.frozenboost.com/index.php?cPath=218&osCsid=b85d68c222344cb3445ef8865c386559
a mate of mine is going to convert a type 2 to wrx power shortly so ill be watching your progress  _________________ Think......
ping Jedi Master
Posted: Wed Mar 26, 2014 10:15 pm Post subject: |
| I'm not going to start mine until winter now. I'm just doing some homework on bits and bobs for now👍 |
ping Jedi Master
Posted: Tue Apr 08, 2014 12:33 pm Post subject: |
| Anyone moved their turbo? Looking at putting it under the batery tray on the near side (not actually under the batery) |
Posted: Thu Apr 10, 2014 11:38 am Post subject: |
| I didn't move the turbo but raised the fuel tank, I also plan to use one of those turbo blanket things and heat sheilds. |
ping Jedi Master
Posted: Fri Apr 11, 2014 8:54 am Post subject: |
| Cheers. I defiantly don't want to raise the fuel tank! |
easy-does-it Jedi Guardian
Posted: Fri Apr 18, 2014 9:36 am Post subject: |
I moved mine.......
Or check out Turbo T2's legendary build in kool rides.. _________________ '76 bay going superfly TDI |
ping Jedi Master
Posted: Wed Apr 23, 2014 10:42 am Post subject: |
| That's the ticket! How did you mount your turbo there? I'm thinking of having mine away from the engine entirely. Can you remember what thread size the banjo fittings are? |
ping Jedi Master
Posted: Wed Apr 23, 2014 11:05 am Post subject: |
| I found a company called sandparts.com I like the look if their turbo setup and no intercooler. |
ping Jedi Master
Posted: Wed Apr 23, 2014 8:49 pm Post subject: |
| Cheers. Your manifold is similar to when I did a N/A manifold. Thanks for the eBay link. |
