Posted: Fri Jan 24, 2014 8:46 am Post subject: Blue and White Immobiliser wire, where does it go
Hi guys
Still trying to get this Immo sorted, I have a horrible feeling that I've been shafted by someone who said the Immo, ECU and key were matched, I'm beginning to think they are not.
Anyhow, got everything wired up on the bench, apart from one wire, it is a blue and white wire, goes from pin 5 on the B141 connector (which is the one that goes into the immo unit.)
also can someone also confirm the White and green wire goes to the Key In switch (linked to +12V)
The engine is an EJ25 the doner car was a 1998 legacy, the ECU is the 3 plug type B134, B135, B136
Have attached a photo if anyone has this same unit and can check, that would be awesome.
Also can anyone confirm the way the immo works, Light flashing once every 2-3 seconds, and when the key is in the coil and ignition on, the light should go out, or stay on if key not recognised.
According to my wiring diagram blue & white wire would go to the right hand door switch which then just goes to earth, so just put it to earth,this is what I've done on mine and it works, one thing I will ad is the key has to be in the exact position it would of been in the the car or it won't work, I found this out the hard way.
Brilliant, will have a try in the morning, havn't got the diagram in front of me, but can you also confirm that the White/Green wire goes to +12 via the Key in switch.
Would be interested in a copy of your wiring diagram if possible, as I cant seem to find any that relate to this actual immo system,
hi yes white and green i have put to ignition live, i have purchased loads of diagrams in the past month and i have only found one which had this info, heres the ebay item num 291068523393 its £4 and is the best one ive found yet, over 3k pages pdf files
Well got my disk today, but can not find any with the immo unit shown, I don't suppose you can tell me which one it is in as my eyes are now blurry after spending all afternoon looking through these diagrams.
