Bigbadbugga Jedi Knight
Joined: 25 Jan 2009 Posts: 160 Location: nr Liverpool, uk
Posted: Wed Feb 29, 2012 7:30 pm Post subject: Subaru EJ25 SOHC+ECU and loom |
This is a Single overhead cam 2.5L engine from a 1999 (T) Subaru Legacy outback Auto.
Suitable for spares or rebuild.
It comes with the complete front wiring loom uncut and as it came out of the car, including the fusebox, engine loom, ECU and most importantly the key and transponder aerial. (see pics)
also included are the starter motor (auto), alternator, p/s and aircon pumps. Exhaust manifold also (not pictured)
The engine has been partially dismantled due to it needing head gaskets (i bought it knowing it had suffered failiour), all the parts, nuts and bolts are bagged and tagged and in the boxed shown.
The cylinders have suffered some light surface corrosion through bad storage on my part, they have not been wet its just through condensation (i should have packed them with grease:(). So realistically the cylinders will need honing. The engine turned freely before the surface rust and so should now, but I don't want to try in case it scores the cylinders. There is no perceivable play in the big end or crank bearings.
Here are the pics....
Block
heads and manifold
boxes of bits
key and electrics (loom in box)
I'm looking for just £100 ono for all of this, will need collecting from L35 postcode near Liverpool.
:paypal: or cash on collection. _________________ Located near Liverpool.
Building a full custom 1972 Beetle with an EJ25 (n/a sohc),Porsche 944 IRS conversion and Rjes bellhousing. |
