trainspotter Force Sensitive
Posted: Tue Sep 27, 2011 6:09 pm Post subject: Fitting a Heater |
I have now fitted the engine and want to connect a proper heater at the front, ideally to connect to the original pipes at the front - any pics, guides ideas
All would be greatly received?
Thanks
Trainspotter |
Posted: Tue Sep 27, 2011 7:55 pm Post subject: |
think theres photo's of my old heater setup in my old tdi twin slider bay basically folded a steel box slipped mk2 golf heater matrix in it fitted that into totum pole that feeds the dash feed with a 3 speed electric fan under the cab floor worked amazzingly used van in snow and all winter and was as hot as a modern car used to clear ice off the screen in the morning no probs  _________________ 1964 rat 13 window deluxe 1Z tdi,
Posted: Tue Sep 27, 2011 7:57 pm Post subject: |
did same on the split but mounted heater matrix under cab floor loks totally stock from inside other than for extra switch on the dash _________________ 1964 rat 13 window deluxe 1Z tdi,
Obonobo Jedi Knight
Posted: Thu Sep 29, 2011 10:13 am Post subject: |
This is my solution:
It is a T25 rear heater, modelled a funnel that connects to the central rising pipe. Bent some aluminum to form a support. Used a Beetle switch on the dash. All in all an evenings amount of work.
You can find more pics in my thread: here. _________________ Greetings from Sietze
Posted: Thu Sep 29, 2011 8:16 pm Post subject: Heater |
Hi
Thanks for the advice I will try and get a heater matrix from the scrappers and see how I fair
Trainspotter |
StuartC Initiate Jedi
