tuzza123 Force Sensitive
Joined: 26 Feb 2011 Posts: 24 Location: Cannock Staffs
Posted: Tue Feb 07, 2012 10:53 am Post subject: Heater bypass |
| I can see the point of heater bypass but surely making a bridge between the pipes before heater will affect the water flow when heater is on reducing heat output |
steamo Jedi Knight
Posted: Thu Feb 09, 2012 10:14 pm Post subject: |
| You could have a valve switching water flow to either the bypass ot the heater matrix. Thats how it works in an old mini IIRC (normally a cable operated valve) hope it helps. |
Posted: Fri Feb 10, 2012 7:40 pm Post subject: heater bypass |
Thanks for info have solved problem as the heater have fitted blows into old Vw duct pipe I have made a flap to block output the nice bit is that it is still controlled by origional knob in cab .
I would post a picture but but cannot use this complicated method |
