smartdriver Padawan
Posted: Tue Apr 17, 2012 8:35 am Post subject: Turbo on a N/A 2ltr quadcam with LPi |
Hi there,
Still very busy with my project but thinking about my engine.
I would like to fit a turbo on it but that gives alot of thermal energy that will reak havoc on the pistons.
As some of you will remember i want to drive mine on LPi but that changed after getting in contact with my supplier of the standalone ecu from KDFI.
http://www.vwkd.co.uk/bb/viewtopic.php?t=1355&highlight=&sid=c23e3e3d38f947ff61eb9fd515687043
He's not a great fan of LPi (he build his system with VSi) because of the regular pompfailures and noise from it and very important the extra almost freezing cooling which you get when liquid gas instantly has to evapourate.
This cooling has so much capacity that it'll freeze up the intake and nozzles.
I scouted the web for problems concerning LPi pumpfailures, noise and freezing but i'm unable to find any!
As i already wrote in my first article on LPi, it has a higher octane ratio so knocking should be avoided.
Therefor would i be safe to put a turbo on a N/A engine if i use LPi as fuel?
Anyone like to share his opinion? _________________ convertin' a VW T2 t1 '69 15 window "splitty" into a daily driver, to be continued....... |
Posted: Wed Apr 18, 2012 5:41 pm Post subject: |
I'know nothing about LPI or any of the other abbreviations you mentioned.
I do however happen to have a lot of turbo spares knocking around if your interested. Not sure about the postage to you or how easily you can source the parts in your neck of the wood. But figured id offer them to you [/list] _________________ Think......
smartdriver Padawan
Posted: Thu Apr 19, 2012 7:12 am Post subject: |
| Kai wrote: |
I do however happen to have a lot of turbo spares knocking around if your interested. Not sure about the postage to you or how easily you can source the parts in your neck of the wood. But figured id offer them to you [/list] |
I'll keep that in mind Kai
But first i have to findout if this is possible.
Cheers,
Paul _________________ convertin' a VW T2 t1 '69 15 window "splitty" into a daily driver, to be continued....... |
