ecu pinout legacy 2.0
lucas889
PostPosted: Wed Oct 12, 2011 7:28 pm    Post subject: ecu pinout legacy 2.0 Reply with quote
would anyone happen o have a pinout for the legacy non turbo?? would love you long time! Love id be greatfull if someone could actually say this is the right one cos i cant be too sure cheers anyroad!
ecu numbers!
8k 22611 ac840 a18 000 dj5
scotty1
PostPosted: Sun Jul 08, 2012 4:51 pm    Post subject: Reply with quote
I also req this ecu pinout or wiring diagram for a project however days of searching on lots of forums have turned up nothing Cry someone must have this info,
somewhere pls help us.
PostPosted: Sun Jul 08, 2012 9:15 pm    Post subject: Reply with quote
What year or how many plugs for the ecu?
Uk model or import?
scotty1
PostPosted: Mon Jul 09, 2012 10:58 am    Post subject: Reply with quote
Hi, thanks for the reply it's a uk 1997 ej22e awd
Ecu has three grey plugs, going into one yellow connector
Marked dj5 I'm in the process
Of tracing wires from the engine to the ecu
For a pinout chart, but the problem is the
Loom was removed not by myself and there
Is some of the rear loom missin, but nothing
From the ecu end.I think this ecu is ob1
As I have yet to find the ob2 plug on the loom
This is one of the reasons I need the org
Wire diagram.
PostPosted: Mon Jul 09, 2012 12:12 pm    Post subject: Reply with quote
I know more about EJ20's through my personal experience.
When I've converted my loom, done two now, the Only thing that goes to the back of the vehicle which is require to run the car is the fuel pump +12v.
With my looms I had two large multipin connectors held together by an 10mm screw.
I've cut those plugs off from the front part of the loom and large part of the loom will come away.
There are a couple of plugs going into the engine loom, grey plugs around 30mm square shaped, the ones you would unplug to pull the engine. Leave those connected, most wires go there from the ecu. Then all you need to find is less then 10 cables from the ecu.
I'm being vague here I know. This approach worked for my phase one engine. Im sure the phase 1.5 of yours has an immobiliser to contend with too.
My point is that there isn't much going to the back of the car required by the ecu other then the fuel pump which is obviously comin from the fuel pump relay.
I'll have a looks around and see it I can find anything that can help you.
scotty1
PostPosted: Fri Jul 13, 2012 11:04 am    Post subject: Reply with quote
I have this just about sorted I will post
The pinouts chart when complete
milkabus
PostPosted: Sun Oct 06, 2013 3:55 pm    Post subject: 8k ECU Reply with quote
Any luck with that pin out yet ? still trying to find one myself ive got the loom hanging from the garage ceiling like somthing out of silence of the lambs and really could do with making a little progress
steve_d
PostPosted: Fri Nov 22, 2013 10:15 pm    Post subject: Reply with quote
Try here for all the wiring and service info
http://jdmfsm.info/Auto/Japan/Subaru/
Just found this myself whilst looking for 2.5 1997
Steve
