best fuel tank set up
geedub
PostPosted: Wed Sep 28, 2011 7:19 am    Post subject: best fuel tank set up Reply with quote
Hi I have been looking at different methods of fuel tank and fuel pump set ups.I was just wondering what some of you think is the best set up for a 2 liter turbo in a 1303 bug.There seems a few issues ie flow rate,fuel line sizes,fuel pump types and fuel pump noise, breather pipes,vented fuel caps and fuel starvation.Ary ideas/recomendatios would be great.
ricola
PostPosted: Wed Sep 28, 2011 5:46 pm    Post subject: Reply with quote
mine Wink
http://www.ricola.co.uk
geedub
PostPosted: Wed Sep 28, 2011 9:15 pm    Post subject: best fuel tank set up Reply with quote
Hi thanks for the response Ricola , had a look at your setup, have you got a diagram for this as I am a bit confused on the venting pipes on the 1303 and the best place for the fuel return from the engine.Also do you have a vented filler cap ? and isyour in-tank subaru pump quiet ?
ricola
PostPosted: Thu Sep 29, 2011 6:29 pm    Post subject: Reply with quote
All tank venting is stock 1303, stock fuel cap. Fuel return is via subaru assembly..
It's much quieter than an external pump and I don't have any trim yet...
geedub
PostPosted: Thu Sep 29, 2011 8:28 pm    Post subject: fuel tank setup Reply with quote
Ok Ricola thanks for that I believe the 1303 had a vent pipe that ran to a canister under the rear wing,are you still using this.And what happens if there is a problem with the subaru pump can it easily be removed for replacement. Sorry for all the various questions I just want to get this part of my conversion right.rgds geedub
ricola
PostPosted: Fri Sep 30, 2011 7:39 pm    Post subject: Reply with quote
I scrapped all the engine end fuel system from the bug engine so not sure! With the subaru fitting it drops in from the top so easy to remove if necessary...
