splitbus67 Padawan
Posted: Sun Aug 12, 2012 7:03 am Post subject: Tank Vent in a Spilt - EJ20 NA |
EJ20 NA
I've notice that the vent from my tank is dripping a small amount of fuel onto the ground when I park up. I don't run the tank full so could this be a result of fuel vapour condensation in the tube?
I have a Bay tank fitted in my split and have the tank vented via some tubing to behind the rear wheel, the tube is routed is downwards from the top of the tank due to height restrictions in the engine bay.
Is this the correct way of doing it? |
ricola Jedi Master
Posted: Sun Aug 12, 2012 7:41 am Post subject: |
the vent tube should go up from the tank and then loop back down.. _________________ http://www.ricola.co.uk |
Obonobo Jedi Knight
Posted: Mon Aug 13, 2012 8:27 am Post subject: |
Here's an image of how the venting and tubing of a Bay works. The vent tubes eventually go to the airfilter.
The tubes that go up bend behind the 'ears' of a bay, where fuel vapour condenses again. _________________ Greetings from Sietze
Posted: Sun Aug 19, 2012 9:37 pm Post subject: |
Red - tricky lil devil???
Pain in the backside more like  _________________ The advice you receive on here is worth the paper it's written on.
splitbus67 Padawan
Posted: Tue Aug 21, 2012 6:20 pm Post subject: |
Thanks
Ah yes the red one! I think the skin on my hand has just recovered from the one I replaced on a friends bus in March! |
