ttriebler Padawan
Posted: Mon Oct 17, 2011 1:39 pm Post subject: Bay Kombi with EJ25 Turbo and Subaru 5 speed |
Just completed this Kombi with STi EJ25T shortblock, EJ20 heads, Liberty water to air intercooler. Perfectly matched with a Subarugears Subaru 5 speed. Fitted Subaru hydraulic master and slave cylinder for hydraulic clutch. Standard axles and CV's bolt straight up.
Shift rod bolts up to Subaru shift rod with a universal joint at eigther end plus a support bearing in the centre to provide slick, tight shifts.
A couple of pix here for general info, more at www.subarugears.com
 _________________ Reversed gears for Subaru Transmissions
Fit a 5 apeed to your rear engined car
www.subarugears.com |
