Davies Craig water pump
Auto
PostPosted: Wed Jun 29, 2011 4:31 pm    Post subject: Davies Craig water pump Reply with quote
Hi Folks
has any one fitted a Davis craig water pump? if so did you remove the thermostat or re drill the thermostat hole bigger ?
cheers phil
Joel
PostPosted: Thu Jun 30, 2011 3:26 am    Post subject: Reply with quote
Why would you want to?
That's just over complicating and adding a potential weak link for no reason.
The stock Subi water pump and thermostat work to perfection even in our bastardised cooling systems.
edit. assuming Subi engine?
