ping Jedi Master
Posted: Mon Mar 21, 2011 7:29 pm Post subject: Running problem to do with air filter. |
| I had the subi engine running today but I could only keep it running by putting my hand over the air in let, using my hand to control how it runs i.e. when it's idling I need to kind of half cover the inlet and when the revs are up I can remove my hand. I tried fitting a piper cross air filter but it won't keep running past a couple of seconds. Any ideas of what the problem could be other than a hose off or broken on the air pipe? |
Posted: Mon Mar 21, 2011 9:00 pm Post subject: |
you've got a air leak somewhere making it run lean covering the inlet is making it richer like a choke flap _________________ 1964 rat 13 window deluxe 1Z tdi,
Posted: Tue Mar 22, 2011 10:51 pm Post subject: |
After air leaks I'd suggest: sticking IAC valve or MAF (buggered or bad connection) _________________ The advice you receive on here is worth the paper it's written on.
ping Jedi Master
Posted: Wed Mar 23, 2011 1:22 pm Post subject: |
| Its the MAF, i checked the codes and got one for that, it will run if i uplug it too so i've ordered a new one. |
Posted: Wed Mar 23, 2011 10:10 pm Post subject: |
Whadda we win? _________________ The advice you receive on here is worth the paper it's written on.
ping Jedi Master
Posted: Fri Mar 25, 2011 5:15 pm Post subject: |
| Satisfaction knowing you knew! |
Posted: Fri Mar 25, 2011 5:40 pm Post subject: |
