Starting/ igniter problems
gdr
PostPosted: Thu Mar 17, 2011 10:46 pm    Post subject: Starting/ igniter problems Reply with quote
Well it never ends I finally got the bus running and all wired up then it stopped starting would crank but not fire thought i had got to the bottom of it eventually after I replaced the igniter it fired into life.
After finishing tidying up the loom I thought I would try it again, but same problem happened however my mate was working in the engine bay at the same time noticed the igniter was really hot, does anyone have any ideas?
PostPosted: Thu Mar 17, 2011 11:06 pm    Post subject: Reply with quote
Have you got the ignitor bolted to a big bit of metal? eg bulkhead etc
They use the chassis as a heat sink. On a Scooby they're often bolted on the bulkhead.
Might be ok when it cools down *crosses fingers*
gdr
PostPosted: Thu Mar 17, 2011 11:37 pm    Post subject: Reply with quote
Its bolted to the body on the bracket that came with the Subaru, should that be ok or should i bolt it direct to the body, thanks for you help
PostPosted: Fri Mar 18, 2011 12:15 am    Post subject: Reply with quote
Not really too sure. Mine's bolted directly to the radius on the spare wheel well. Can't find a photo, sorry
I have heard they can get hot, hence being bolted to a big bit of metal
Did it run on all 4 cylinders? Was it dead smooth idle? Is yours a twin coil pack bolted onto the manifold?
gdr
PostPosted: Fri Mar 18, 2011 3:25 pm    Post subject: Reply with quote
Ran on all 4 cylinders and seemed smooth, its a single coil pack bolted the manifold, went into the Subaru garage to get a new one, you could of scraped me of the floor when i heard the price, needless to say I didn't buy one and will hopefully manage to pick one up second hand
ping
PostPosted: Fri Mar 18, 2011 4:20 pm    Post subject: Reply with quote
I bought one last week from my local motor factors for 108 pounds inc VAT.
PostPosted: Fri Mar 18, 2011 5:42 pm    Post subject: Reply with quote
Test the coil pack before getting another
gdr
PostPosted: Sat Mar 19, 2011 11:50 am    Post subject: Reply with quote
Wow lucky you I went to my local motor factors and they don't do them tol me to go to Subaru who quoted me over 3x as much
