EJ20G coil pack conversion
PostPosted: Sun Mar 06, 2011 7:34 pm    Post subject: EJ20G coil pack conversion Reply with quote
Well i found this little right up on converting the old style of coil pack found on the classic pre facelift Impreza and I guess Foresta... Subaru's fitted with the EJ20G engine.
It's a bleeding good right up and looks to be a simple fix a very common problem on these engines where the coil pack cracks and fractures the plastic housing causing ignition problems.
I'm currently getting no spark from my plugs at the minute and if I end up having to replace the coil packs then I will definitely be doing it this way.
http://forums.nasioc.com/forums/showthread.php?t=1192028
It would be nice to see this as a sticky I think.
PostPosted: Sun Mar 06, 2011 11:46 pm    Post subject: Reply with quote
ill have to get pics of a simpler conversion on here using a single coil pack conversion same as other ej engines
BlackCosmos
PostPosted: Mon Mar 07, 2011 2:25 pm    Post subject: Reply with quote
would this mean i could change from coil packs to the later single coil and leads on an early turbo engine??
PostPosted: Mon Mar 07, 2011 2:35 pm    Post subject: Reply with quote
yes ,beanie has done it on his Wink
BlackCosmos
PostPosted: Sun Mar 13, 2011 8:52 am    Post subject: Reply with quote
cool..be handy if you could post those pics!!
