Davecrook1 Padawan
Posted: Sun Feb 20, 2011 11:28 pm Post subject: Skipping around the immobiliser... |
Theoretically there must be a way to dodge around the immobiler... What does it prevent coming on? Elec to ecu?power to fuel
pump? I seem to be missing the immobiliser on my loom so am thinking how I could go about getting around it?
There must be a way otherwise got bags wouldn't be able to nick them! |
doppelganger Jedi Guardian
Posted: Mon Feb 21, 2011 11:27 pm Post subject: Re: Skipping around the immobiliser... |
| Davecrook1 wrote: | Theoretically there must be a way to dodge around the immobiler... What does it prevent coming on? Elec to ecu?power to fuel
pretty sure you will be wasting your time  _________________ vwdrc class rep
Davecrook1 Padawan
Posted: Tue Feb 22, 2011 9:14 pm Post subject: |
| Bugger |
1303Steve Jedi Knight
Joined: 07 Aug 2009 Posts: 208 Location: Sydney, Australia
Posted: Wed Feb 23, 2011 9:59 pm Post subject: |
Hi
I bought my motor and loom without a key, barrel and ignition wiring loom, I had to get all of them and have a key programmed, the key and barrel just sit under the back seat now.
Steve _________________ STI powered 1303 now running
G50 box, Boxster/944 brakes, Adaptronic 1280E ecu, PWR intercooler etc |
Griff71 Jedi Knight
Posted: Mon Feb 28, 2011 10:11 pm Post subject: |
Often wondered about the significance of my key. Found it had fallen out of the barrel once and motor was still starting and running, reckon it had been out a week. Have it all taped up now so it can't move. Sounds crazy but is it likely the ecu can reset itself to to run without.
I also thought i needed a speed sensor 3 years ago when i fitted conversion. Would stall at junctions or if i took my foot of the accelerater and coasted. Put up with it for a few weeks and all of a sudden it stopped 50k later still no vss fitted and no stalling. _________________ 89 Crew Cab (Subaru 2.5na)
71 Drag Bug (1955cc dual 40s)
65 Ragtop Bug (low & stock) |
Posted: Mon Feb 28, 2011 10:57 pm Post subject: |
Hi Griff71
When your key fell out maybe the chip in the key was still close enough to be read by the switch.
ping Jedi Master
Joined: 11 Aug 2008 Posts: 254 Location: Warwickshire
Posted: Tue Mar 01, 2011 3:02 pm Post subject: |
| 1303Steve wrote: | Hi
Steve |
How did you do that? There must be amarket for that sort of thing (key, antena/barrel, wiring and coding) as a kit for people having this problem. |
Posted: Wed Mar 02, 2011 1:05 am Post subject: |
| ping wrote: | | 1303Steve wrote: | Hi
Steve |
Hi
I bought a 2nd hand barrel from a wrecker and had a Subaru dealer program the key, most locksmiths can program keys.
ping Jedi Master
Posted: Wed Mar 02, 2011 4:05 pm Post subject: |
| What about the imobiliser unit? I tought this, the barrel the ecu and the key all had to match? |
gazman Padawan
Posted: Thu Mar 03, 2011 12:31 pm Post subject: |
Hi
The trouble with that idea is the cost of the unit plus dyno time to set it up and it will never work as well as the standard ECU unless your talking about a modified motor. If the motor has variable valve timing like my motor you need a very sophisticated ECU to make it all work.
I'm not a fan of microtech, aka electric carburettor. I have a plug and play Autronic SM4 for my STI bug, I have changed the exhaust and inlet track so the motor will benefit from the extra tuning that an after market ECU can offer. The ECU is worth about $2600 and a few 100+ to tune it.
I had my loom modified by these people http://amauto.com.au
I asked about deleting the immobiliser, they said it wasn't possible and having a 2nd hand barrel and key recoded was the only way to go.
